Here some updates about the strange behaviour in my SER9 pro. The external nvme attached to the USG4 port seems to to work fine, now, after connected it to the usb4, using a microsoft adapter! don’t understand how it works, now, probably depending by an incompatibility with the nwme case directly connected to the beelink port…
Hope the problems are finished, now.
If you have some other suggestions, please reply to me.
thanks
