centoj
Could you please send us a picture of SN code(two lines) at the bottom of machine ?
Next,please take out one RAM and leave the other one in it to test if the RAM is defective or not.
When testing, please turn on the PC, and wait about one minute, if you can go to the system, Please repeatedly press delete key as soon as your restart the PC, go to BIOS.
Go to Boot option, enable fast boot, press F4 to save. (If the PC comes with onboard RAM, you can ignore this solution )
②Please repeatedly press delete key as soon as you turn on the PC, go to BIOS.
Please send us a picture of the Main page, we will check if you need to update the BIOS.
④Overheating. If your PC is overheating, please check if the fan spins. You can also turn off the turbo boost.
Go to control panel —power option—change to High performance— change plan setting—advanced setting —processor power management— change both 100% to 99% , click save.
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one.
Here is the driver file: https://url.bee-link.cn/bcEf
The tutorial: https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Have a nice day~
