None of the fixes listed worked.
This is what I see from my Device Manager or Sound Settings. When I try and update the drivers of the items (Unknown device etc.) with the yellow exclamation mark by selecting the folder I downloaded, none are found (“Windows was unable to install your unknown device”)
This is the pic you requested. Hope you have a solution otherwise I’m asking Amazon for a refund
