I am using the Beelink Mate Mini A hub and have encountered an issue when my computer goes into sleep mode.
When the computer enters sleep mode, the hub itself does not go to sleep. The fan continues spinning and the white LED indicator remains on.
This is less critical when using it with a Mac mini, but when I use it with a MacBook Pro it significantly drains the laptop’s battery while the computer is sleeping.
Could you please advise if this is expected behavior or if there is a way to make the hub enter sleep mode together with the computer?
Thank you.
Best regards,
