My Beelink U59 Pro BIOS v2.21.1278 does not retain auto-boot up settings. I have configured S0 state (was S5 default). Is there a reason or perhaps some newer BIOS that works? When power is disconnected and reconnected after a clean shutdown, the device does not auto start even though I have this set correctly to S0 and “saved+exit” in BIOS each time. When I go back and check the BIOS setting, it has changed back to S5 and hence will not auto start/bootup. I have changed the CMOS battery and it is >3V (New), same issue persists.
Assistance would be greatly appreciated, thank you.
