Beelink CS-June Raphael_otio Hello there, Here are some solutions: Save your settings first, then configure the boot options: Enter the BIOS, navigate to Advanced > Network Stack Configuration, ensure it is enabled, and press F4 to save. Restart the system, re-enter the BIOS, go to Boot > UEFI NETWORK Drive BBS Priorities, and set the PXE network adapter as Boot Option #1. Then, return to Boot > Fixed Boot Order, set this network option as the first item, and press F4 to save. Quick verification: Repeatedly press F7 during startup to access the boot menu, then select the network adapter entry that includes “UEFI PXE IPv4” in its name. If this option appears, the BIOS has correctly identified the adapter, and you can proceed with a network boot. If no network option appears in the boot list: Ensure that CSM is set to Disabled, as PXE is only enumerated in UEFI mode. Also, verify that the Ethernet cable is plugged in and the switch port indicator light is on; some BIOS versions will only enumerate a network adapter if a valid link is detected. If the client reaches the “Start PXE over IPv4” stage but stalls, or if there is no response from the DHCP server, the issue lies with the server side. PXE requires a DHCP server and a TFTP (or HTTP) server to provide the necessary boot files; no further configuration is required on the client (host) side. Have a nice day~
Raphael_otio There is no CSM option in the bios. Only secure boot. Setting it to enabled or disabled does not affect the IPV4 pxe option as it does not show up regardless
Beelink CS-June Raphael_otio Hello there, Would you be willing to consider sending the machine back for repair to see if it can solve the problem? Could you please send us a picture of SN code(two lines) at the bottom of machine ? Have a nice day~
Raphael_otio Beelink CS-June Product:Mini PC 8B.024500838AB0 SN:B77356FH90161 SER5 MAX-L-24500EJOW64PRO-DP/XA
Beelink CS-June Raphael_otio Hello there, Thanks for your reply~ If you would like to send the machine back for repair, please contact our after-sales email – support-pc@bee-link.com Have a nice day~
