Aruna I bought Beelink SER9 HX370 Mini PC, 12C/24T up to 5.1GHz, 32GB LPDDR5X and 1TB M.2 PCle4.0 SSD, the power adapter states 100-120V. Is there a power adapter which i can use for 220-240 V supply? or if i use 120W USB-c power adapters, is it oke?
Beelink CS-Rose Aruna Although our power supply is labeled 100-120V, it can actually be used with voltages from 100-240V. If the voltage is 120V, you can use a 120W USB-C power adapter.
