I just did a fresh install of windows 11 pro on my SER8 with the AMD Ryzen 7 8845HS and Radeon 780M Graphics.
The issue is very low sound on the (front) headphone jack port with any headphones plugged in.
The interesting part is that I had the very same issue when I previously installed Fedora Workstation 43 on the very same SER8.
I went thru all the problem solving steps on both my current Windows 11 pro (and Fedora linux when it was installed), but the issue is still there, and I’m running out of ideas.
As far as I can tell, my new Windows 11 Pro install is using Microsoft’s audio drivers. Not sure what I had on Fedora.
I would really appreciate any help or advice. I’ve been very pleased with my SER8 except for this issue.
Thank you,
Burt Prior
