LennyS
Please do not update the BIOS for now. Please try the following solution first.
Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc
Please change another power supply.
Overheating. If your PC is overheating, please check if the fan spins. You can also turn off the turbo boost. Go to control panel —power option—change to High performance— change plan setting—advanced setting —processor power management— change both 100% to 99% , click save.
Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :https://url.bee-link.cn/SzSO Tutorial:https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Pls backup your data firstly, re-installing the system will make your data in your pc lost.
You can go to Microsoft to reinstall the system.
Here is the tutorial: https://url.bee-link.cn/74zu
If the problem still cannot be resolved, please contact our after-sales email. We will provide you with further after-sales service during the warranty period: support-pc@bee-link.com
