Im2 I have a ME Pro 2-Bay Hybrid NAS (N150). I can’t find an option in the BIOS to disable the POST beep sound at system startup. Perhaps I just didn’t look carefully. The sound is very loud and annoying, please tell me how to disable it.
Beelink CS-Sylvia Please repeatedly press delete key as soon as you turn on the PC, go to BIOS–go to Boot menu–Beep function–change it to disabled–Press F4 to save and exit
Beelink CS-Yvette Im2 Hello there, Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
