My Ser8 is running as a headless Ubuntu server.
Recently, last 2 weeks, the fans have been spinning continuously at high volume. The fans are spinning even when I’m sitting in the BIOS.
I’ve re-installed the OS, removed all docker containers, looked at the outputs of Htop, sensors, and so on but cannot isolate the reason for the fans spinning continuously and the air exhaust is constant.
BIOS has been flashed to February 2026.
Hardware Monitor reports 24°C for the CPU
In the BIOS the fan is fixed at 2800 RPM.
Manual PWM changes have no effect.
The case is room temperature.
I’ve cleaned the dust filter/guard.
Not sure what else I can check.
