Issue Description
When recording with Mate Pro connected to a Mac, you may encounter distorted sound or constant buzzing/static noise. This problem is caused by incorrect audio sample rate settings. Switching the sample rate to 48000Hz will resolve the issue completely.
Step-by-Step Instructions
1.Open the system menu and launch Audio MIDI Setup.
2.Select USBAudio1.02, then change its format to 48000Hz.
