thrfreitas
Don’t worry, the PC has three-year warranty. Please send us a picture of SN on the bottom of the PC and a picture of the purchase record.
Here are some potential solutions: First,please unplug the power supply and HDMI cable. Please press the pinhole of “CLR CMOS” with a pin for about 10 seconds.Ten minutes later, plug the power supply and HDMI cable, turn on the PC again. Please wait about one or two minute, if you can go to the system, Please repeatedly press delete key as soon as your restart the PC, go to BIOS. Go to Boot option, enable fast boot, press F4 to save. Here is the tutorial [ https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w]. If the problem persists, please try other solutions:
③Please tell us if the Keyboard light is on ?(Very important). If the keyboard light is on, it should go to the system, we need to troubleshoot HDMI or the monitor.
If none of the above methods can solve your problem, Please copy the link to this post and contact our after-sales email, attaching your serial number (SN) and a photo of your proof of purchase; we will arrange for a repair or replacement under warranty.
Here is the email address: support-pc@bee-link.com
