Hello Beelink Support,
I am experiencing recurring random shutdowns with my Beelink SER5 MAX. The computer suddenly powers off completely, without any warning, BSOD, or normal Windows shutdown procedure.
My device information is:
Model: Beelink SER5 MAX
Processor: AMD Ryzen 7 7735HS
Part Number: SER5MAX-L-241TBEJ0W64PRO-DP/XA
Current BIOS Version: ASER5009
Serial Number: B7735****0474
The issue has occurred repeatedly over the past few months and, on some days, several times within a short period.
When the problem happens, the computer completely loses power. The power LED and fan turn off immediately. Windows does not display a blue screen and, in most cases, no crash dump is generated.
Windows Event Viewer consistently records the following events after these shutdowns:
• Kernel-Power – Event ID 41
• EventLog – Event ID 6008 – Unexpected Shutdown
• BugcheckCode = 0
• PowerButtonTimestamp = 0
• SleepInProgress = 0
I have also observed some LiveKernelEvent 141 and AMD_WATCHDOG related events, although these do not appear consistently before every shutdown.
The computer temperatures appear normal, generally around 60°C, and I have not identified an overheating condition associated with the shutdowns.
I have also tested the computer using different electrical outlets, but the random shutdowns continue.
Before making any BIOS changes on my own, I would like Beelink to confirm the appropriate BIOS version for this specific serial number and hardware revision.
I found reports on the official Beelink forum involving SER5 MAX 7735HS units, including the same part number SER5MAX-L-241TBEJ0W64PRO-DP/XA, where users reported similar random shutdowns and Beelink Support recommended reinstalling or reverting to the appropriate original BIOS.
Could you please confirm:
Is there any known issue involving random power-offs on the SER5 MAX 7735HS with BIOS ASER5009 or with part number SER5MAX-L-241TBEJ0W64PRO-DP/XA?
Is ASER5009 the correct BIOS version for my specific serial number and motherboard revision?
Do you recommend reinstalling the BIOS, upgrading it, or reverting to another BIOS version? If so, please provide the exact BIOS file and instructions applicable to my unit.
Could this behavior be related to the AC power adapter or the internal power circuitry?
Do you recommend testing or replacing the power adapter? If so, please confirm the correct voltage, amperage and wattage specifications for my unit.
I can provide photos of the serial-number label, BIOS main screen, Windows Event Viewer records, and any other diagnostic information you require.
Because the shutdown is abrupt and occurs without a Windows bugcheck, I would particularly appreciate your guidance regarding the BIOS and power-supply possibilities before I perform any firmware changes.
Thank you.
