vfxjfb
Sorry for your waiting.
We sincerely apologize for the inconvenience caused by the malfunction of SER10.
At present, regarding your inquiry about which version of the AQC113 firmware should be installed for the machine and whether there is an updated version of AQC113 firmware, as well as whether the AQC113 firmware on your machine is the latest version, we are inquiring with the corresponding R&D personnel.
For the freeze (hang) problem of the AQC113 in SER10, the R&D department is developing a repair solution.
We will contact you as soon as there is a further solution from the R&D personnel.
If the problem can be solved by replacing or repairing later, we will also contact you as soon as possible.
Thank you for your understanding.
Have a nice day~
rpy123 and @Beechain
Have a nice day~
