BaltimoreBrett Ive seen another post on this, but got a ser5 max l and there is no audio from the hdmi. Ive installed the amd drivers and still nothing. The pc lists both an amd and realtek output. Not sure which is the amd, but neither work
Beelink CS-Yvette BaltimoreBrett Sorry for the trouble. Could you please send us a picture of SN on the bottom of the PC ? Here are some potential solutions: 1.Please right click window–click “”setting“—Sound—-more sound setting –click “playback”–right click speaker—properties–controller information —properties—update the driver. You also need to check if the speakers is disabled or not in the playback setting. Here is alternative to troubleshoot the audio problem. https://thegeekpage.com/fix-this-device-cannot-start-code-10-error-in-sound-devices-on-windows-10/#:~:text=%E2%80%9CThis%20device%20cannot%20start.,driver%20installed%20on%20your%20computer. Here is the driver for you to update, Here is the driver :[https://dr.bee-link.cn/?dir=] click the item model , then you can find the related driver.I will send you the corresponding driver after confirming the specific model of your device. Please turn off the PC , unplug the power supply, and press the CMOS button (or put the pin into the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial [https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w]or [https://url.bee-link.cn/5FdW] Please go to device manager, uninstall the audio driver, then restart the PC.
