Hello Beelink Support,
I’m experiencing intermittent hardware initialization issues with my Beelink SER9 Pro running Windows 11.
System information:
- BIOS: SER9T407 (December 17, 2025)
- Ethernet: Realtek Gaming 2.5GbE Family Controller (RTL8125)
- Wi-Fi: Intel Wi-Fi 6 AX200
- Bluetooth: Intel Wireless Bluetooth
- Bluetooth driver: Intel 24.10.0.4 (November 10, 2025)
1. Ethernet issue
The onboard Realtek Ethernet controller sometimes disappears completely after a Windows restart.
Device Manager / PowerShell reports:
Status: Unknown
Problem: CM_PROB_PHANTOM (Code 45)
Device: PCI\VEN_10EC&DEV_8125
The controller is also absent from Get-NetAdapter -IncludeHidden.
Running pnputil /scan-devices does not restore it.
2. Bluetooth issue
The Intel Bluetooth controller occasionally fails to initialize, including after resuming from hibernation.
I observed:
CM_PROB_FAILED_POST_START (Code 43)
After disabling and re-enabling the device:
CM_PROB_FAILED_START (Code 10)
The device also reported DEVPKEY_Device_ProblemStatus = 0xC000009E (STATUS_DEVICE_POWER_FAILURE).
3. Troubleshooting results
- Full shutdown followed by disconnecting power for 1–2 minutes restored Bluetooth and Ethernet.
- A subsequent hibernation/resume cycle completed successfully, with both devices working.
- A normal Windows restart caused the Realtek Ethernet controller to disappear again, while Bluetooth and Wi-Fi remained operational.
- A Plug and Play hardware rescan did not restore Ethernet.
- A full Windows shutdown (
shutdown /s /t 0) followed by power-on restored Ethernet without physically disconnecting power.
- The Ethernet failure occurred even with the external USB-C hub disconnected.
These results suggest a possible firmware, power-management, or hardware initialization issue, particularly during warm reboot.
Questions:
- Is this a known issue with the SER9 Pro or BIOS SER9T407?
- Is there a validated BIOS update or recommended firmware setting that addresses PCIe/USB initialization problems?
- Are there specific chipset, Ethernet, or Bluetooth driver versions recommended for this model?
- Could these symptoms indicate a hardware fault requiring warranty service?
Thank you for your assistance.
