I bought an EQR6 and am very happy with it. I use it as a game server and remote PC from my network rack.
I can see that there is a wall mount bracket available for it on the website here:
https://www.bee-link.com/products/wall-mounted-bracket
Can someone tell me how this is attached? Does it screw into the bottom using the case screws (under the rubber stops) and then just hang on the wall?
Alternatively, does anyone have a design file for a 3d printed mount that they are willing to share?
Thanks.
