Please provide a product key for Windows 11 Pro activation.
The license status changed after Windows update.
“Windows is not activated.”
Image description
    I also need a product key for Windows 11 Pro activation.
    Image description
      2 months later
      Hello Beelink,
      I have the same problem, can you help me please:Image description
        5 days later
        4 months later
        Please, I need a product key for Windows 11 Pro activation in my Beelink Mini S12 Pro, for installation, after update W. Update, Window is not activated….
        my mini pc dates:
        SN: BN1004AE00856
        minis 12 Pro-A16512SD0W64PRO-B/XB/0
        Thanks advance
          capello
          We have send the key to your private discussion, pls check.
          I also need a Windows 11 Pro activation Key for my EQ13. Can you PM me?
            I too need a Windows 11 Pro activation Key for my S12 Pro. I can send a picture of the serial number when you PM me. Thanks.
            I need also Windows 11 Pro activation key for S12 Pro. Can you PM me and I’ll send the pic of serial?
            I also need the Win 11 Pro activation key for my S12Pro. I’m assuming that’s why I get the Win11 end of life message.
            Thanks.
            Projeckt Please provide a picture of the SN code of the machine and we will send you the corresponding key
            [unknown] Please provide a picture of the SN code of the machine and we will send you the corresponding key
            [unknown] Can you provide the SN code of the machine? I will send you the corresponding key. Looking forward to your reply, wish you have a nice day
              Billy key send to you by pm,please check
              [unknown] key send to you by pm,please check
              Hi all,
              I have the same issue after upgrade. Please provide a product key for Windows 11 Pro activation.
              Photo with SN attached.
              Image description
