I have a Beelink SER6 (https://a.co/d/dK6AfIo).
I have a 10 gigabit thunderbolt ethernet card plugged into a 10 gigabit switch. I am only get 5.6 gigabits according to iperf3.
I know that the ethernet dongle on the other end is able to send and receive 10 gigabits as its been independently tested, as has the switch.
I am running Linux on here; boltctl seems to indicate that it should be working:
[tombert@nixos:~]$ boltctl
● Sabrent Ethernet Adapter
├─ type: peripheral
├─ name: Ethernet Adapter
├─ vendor: Sabrent
├─ uuid: cf030000-0082-8088-20e4-96c4ce253906
├─ generation: Thunderbolt 3
├─ status: authorized
│ ├─ domain: f0833804-c04b-b91b-ffff-ffffffffffff
│ ├─ rx speed: 20 Gb/s = 2 lanes * 10 Gb/s
│ ├─ tx speed: 20 Gb/s = 2 lanes * 10 Gb/s
│ └─ authflags: none
├─ authorized: Sun 02 Jun 2024 11:26:15 PM UTC
├─ connected: Sun 02 Jun 2024 11:26:14 PM UTC
└─ stored: Mon 20 May 2024 04:10:07 PM UTC
├─ policy: auto
└─ key: no
I had a hypothesis that not enough lanes are being used by the card, but I don’t see an option in the bios to set that. Any ideas would be helpful/
