1.The in-game settings might be too demanding for your hardware configuration. Try lowering the graphics quality, resolution, and disabling features like anti-aliasing, shadows, and post-processing effects to see if it improves the FPS. Some older games like GTA V and Bioshock may have default settings that are too high for the integrated graphics to handle smoothly
2.Make sure that your Windows power plan is set to High Performance or a similar option that allows the hardware to run at its full potential.
- Please go to AMD website and download the auto-detect program.
It will update some chipsets and video drivers automatically. It will identify and install appropriate drivers for their AMD hardware. The program works by scanning the user’s system to detect the installed AMD hardware components, such as graphics cards or processors. It then compares the detected hardware information with a database of AMD drivers and software versions.
- Please send us a picture of the Main page of the BIOS, we will check if you need to update the BIOS.
