Hi , there
May i know , is there any driver you need to install from your camera web .
before you can use it .
and please try different ports
Please try some solutions here :
1.Go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
- Disable Fast Startup
In Control Panel, click the Power Options. Select the Choose what the power buttons do. Uncheck the “Turn on fast startup.”, click save changes.
