I have had my Beelink Minis 12 pro-A sense March 2024. SN:BN1004EF20900. Very few problems until recently. Lately, I have been loosing my internet connection. It shows (REALTEC PCIe GbE FAMILY CONTROLLER)
as the problem. The only way I can correct this is to completely shut down the computer with a full reboot.
Is this a software issue or a failing hardware concern?
I can turn on WiFi or BlueTooth but that is not the way I prefer to connect to the internet.
Any help will be greatly appreciated!
Internet Connectivity Problem
1.Please make sure your WIFI signal is full.
Make sure that the distance between the PC and the router is less than 6 meters.
Please uninstall the wifi driver and then resatart the PC to see if it works.
Please right click the windows —setting -troubleshooting —other toubleshooters— internet—run , let the PC diagnose the problem and solve it automatically.
5.Please update the driver. Here is the driver source : https://url.bee-link.cn/PAGjGo to device manager , click the property of the Intel WiFi driver —advanced–choose property 802 ax, value also choose 802 ax.
Please clear the CMOS. Please turn off the PC , unplug the power supply, and put the pin in the pinhole and press it for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms
8.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
9.Please go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
10.Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg or https://url.bee-link.cn/meE5
- Right click windows –go to settings—network & internet—-Advanced network settings–network reset–reset now
