Gti14User Can the ssd screw off-set post be unscrewed? Is yes how can I get a replacement for the screw and post.
Beelink CS-Yvette Hi there, are you referring to hexagonal stud ? They can be unscrewed . Why do you want to a replacement, are they broken? Here is the tutorial on how to open the PC url.bee-link.cn/5Xhe
Gti14User Was trying to add ssd but screw was in so tight that it got stripped. It was really frustrating after having to remove 20 tiny screws just to get into ssd to find out can’t get ssd screw out. I gave support a chance to help but response is 2 days too late.
Beelink CS-Yvette Gti14User Hi there, Sorry for the delay. We have time difference, so we usually reply to you the next morning. Please contact our support at support-pc@bee-link.com to get screw replacement.
