Hello!
I ran the BIOS update program as per your recommendation. The process stopped at this stage and I don’t know what to do next, since your instructions do not correspond to what I see on my screen!
https://mega.nz/file/XYoi1aya#aQjDePeUa2QH_aACKBTHCqMQ4sY94ytVLPWzehD2qjU
https://mega.nz/file/iY5SlDLA#6O3h37zBgTzPh-Dc2kOqwtdN4AlvVk7wWZlYDW44W2w
Help restore my PC Beelink SER 7
I tried to follow the sixth step of the instructions and entered the “DIR” command, and this is what happened.
https://mega.nz/file/bQgw1IBR#OL9LvPAKAhULdhUw_qiJsQMpAdGd_pl4ItzGwfH3kxs
Please give detailed instructions on what to do next!
I figured out the update process and now my device has a new BIOS dated 24/07/2024.
I followed all your recommendations: cleaned the RAM contacts, did Memtest (more than 5 hours, everything is OK), updated the PC BIOS to the recommended one! Unfortunately, this did not solve the problem with the cyclic reboot! Apparently the SSD my SER7 PC has failed.
https://mega.nz/file/vJB1HBSK#4ZNfCAv350uz-k6jtjtDCoixzYI1LXpyCPHUeupFt0g
I am attaching a video with the problem after all the manipulations:
https://mega.nz/file/eQRSFJ5J#tjan1PFR6CuMwzdYWWS9a6TWGJLY4czBG1-lUscDVEQ
Your bios has been updated.
Please try to re-install the system.
Pls backup your data firstly, re-installing the system will make your data in your pc lost.
System: https://url.bee-link.cn/glzL
Tutorial: https://url.bee-link.cn/s88O
