New S-13, Linux (OpenSuSE Leap 15.5) installed. Connected to 1600×1200 monitor with HDMI to DVI cable. Should display at normal 1600×1200 resolution - other machines with same OS do, but I only get low 1280×1024 resolution. (xrandr says that’s the only available resolution.) Amazon info (where I bought it) says it should be able to do up to 3840 × 2160. The adapter cable (Thsucords 4K HDMI to DVI Cable 3.3FT) supports 1600×1200 and above.
Why is this happening, and how do I fix it?
