sjgo sjgo Samsung RAM and Micron Ram, both companies It’s the same reaction, It’s the same symptom when you move to a different location, Micron turns on when you use 2 channels I can’t even hear the fans. I can’t turn it on
sjgo support1 Can’t I ask here? I’ve already inquired here and I’m waiting for your response (support-pc@bee-link.com)
sjgo support1 ‘beelink’ Isn’t this the company? (It’s a non-link product that asked for the serial number in the back. beelink 8845hs barebone pc)
support1 sjgo The brand is 零刻, you can see that the Chinese characters are on the bottom , So you need to contact 零刻 support . Their email is support@lingk.com.cn
