Hi @Yuriy2
I have the same problem as you with Proxmox. The U59 freezes with kernels above 6.8. I tested Proxmox and kernel 6.17 but it didn’t work.
Did you resolved your freeze problem ?
If yes, could you tells us a little more ?
Many thanks for help
Best regards
Lal
