So I am trying to overclock the mini PC in the bios but when I change my ram speed higher, and restart it, it boots but it shows a black screen. Why and what can I do.
When I download the MSI afterburner and overclock the fan or the cpu, I click save but it wont save and overclock. any solutions
    LucarioBedwar Hi there,
    This PC doesn’t support overclock.
    Thank you.
    I have another problem with this PC as well. When I plug it in, it makes a click sound as soon as I plug it in and it won’t turn on, no lights.
      5 days later
      LucarioBedwar
      Please turn off the PC , unplug the power supply and other USB devices, then put the pin in the CMOS pinhole and press it for about 10 seconds , restart the PC after ten minutes.
      Here is the tutorial https://url.bee-link.cn/5FdW
      I did try that, nothing. I tried the ram,
        But I bought it on Christmas 2022. Is the warranty ended?
          6 days later
          LucarioBedwar Hi there, the PC is out of warranty, but you can send it back for repair at your expense.
