Beelink CS-George Same errors with my SEI14, how to fix it
BIOS: SEI14T202
Kernel: 6.16.8-arch2-1
[ 0.374316] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.374349] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.374377] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.374410] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.416024] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.416109] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.416191] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS03._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.416273] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973075] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973085] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973099] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973112] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973120] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.973131] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975276] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975286] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975297] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975310] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975318] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975330] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975342] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975350] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975361] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975373] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975381] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._UPC due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 0.975393] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.442170] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.443660] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.465710] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.466545] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.957212] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 1.958017] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS04._PLD due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
[ 7.177975] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
