Master_Taki Hi, I am requesting the most up-to-date bios for: 9Y.4200830A10 Product: MINI PC SN: Y58504BF90056 SER5 PRO-E-16500EJ0W64PRO-DP/XB
Beelink CS-Rose Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page.We will check if you need to update the BIOS.
Master_Taki It might be a little hard to read, but the version # is: 2.22.1292 (Also I MIGHT not need the bios now if there even is an update, since I might have figured out the Windows 11 update issue I was having)
