PCIe 8 Pin Male to Dual PCIe 8 Pin (6+2) Male Power Adapter Sleeved Cable for Seasonic Modular Power Supply PSU 25-inch+9-inch(63cm+23cm)
Brand YEZriler
Connector type 8 Pin PCIe
Cable type Component
Compatible devices:
(X-1050XM2/X-1250XM2),(SS-660/760/860XP2 series),(X-Series - X-650 KM3/X-750 KM3/X-850 KM3),(SS-1050/1200XP3),(Seasonic_Snow_Silent 750W/1050W),(M12II Evo series 520/620/650/750/850),(Seasonic FOCUS+ series), SSR-1000PD/SSR-1200PD, SSR-600TL
About this item
PCIe 8P - Dual 8P(6+2):PCIe 8 pin male end to plug into the power supply (NOTE: it is PCIe 8 pin, not CPU 8 pin) and two PCIe 8 pin(6+2) male ends to plug into the video graphics card.(NOTE: the 8 pin end and two 8 pin(6+2) male ends cannot be used interchangeably);
Only designed for graphics vedio cards, it doesn't work with motherboards: Compatible with 6-pin & 8-pin graphics cards from regular manufacturers such as: ASUS/ASRock/Gigabyte/Radeon/Sapphire/NVIDIA Tesla/etc.(The 8 pin (6+2) ends could be used as 6 pin or 8 pin end by sliding on/off the 2 pin.);
Compatibility: Compatible with (X-1050XM2/X-1250XM2),(SS-660/760/860XP2 series),(X-Series - X-650 KM3/X-750 KM3/X-850 KM3),(SS-1050/1200XP3),(Seasonic_Snow_Silent 750W/1050W),(M12II Evo series 520/620/650/750/850),(Seasonic FOCUS+ series), SSR-1000PD/SSR-1200PD, SSR-600TL;
Parameter: Length(including connectors): 25-inch + 9-inch(63cm+23cm), Gauge: 1007-18AWG(standard tin-coating copper wire), Quantity: 1pcs, Hook loop strip*1pcs (only designed for graphics vedio cards, it will not work with motherboards);
Attention Please: This cable was only designed for the brand and model as listed in the 3rd Point.(NOT Compatible with Corsair Power Supply) If you use other incompatible brand PSUs or types, it will definitely burn or damage the PSUs or graphics cards. Please carefully check the compatible types or contact us if you are not sure if it supports your power supply;
