Greetings! I am new to Beelink and just purchased a Beelink EQR. I bought this PC to run Linux after reading that many had installed Linux on these EQRs with success. I am running OpenMandriva 25.03 with kernal 6.14. My CPU is a Ryzen 9 6900HX.
The WIFI adapter, which is a Wifi 6 200 ax is not recognized, and the bluetooth adapter only shows numbers for my devices and I cannot connect to anything. The LAN works just fine. I assume this is a driver issue, but the kernal should have these already installed.
I tried a live boot of Kubuntu as well, and had the same issues. Can someone point me in the right direction? Thank you!
