t1me2die Dear Team, I’ve got an GTI13 Ultra and I recognized that the GTI13 Ultra takes 3Watt per hour if the pc is completly switched off. Why and how can I fix it? I dont want to pull out the power plug. Is it happened because of WOL? I’ve to switched WOL off like the tutorial here: https://www.bee-link.com/en-de/blogs/knowledge-base-guides/wake-on-lan-1
Beelink CS-Yvette Hi there, please follow the tutorial https://buildin.ai/lizong/724d0766-6e0a-4dc1-9347-2c4c2cea2d05
t1me2die Doenst fix the problem. The power consumtion is still around 3watts. So no problem, I’ll pull out the power plug. But this power consumtion is not allowed in the EU! The standby consumption must not exceed 0.5 watts. You can read here everything of it: https://energy-efficient-products.ec.europa.eu/product-list/standby-networked-standby-and-mode_en Maybe your Devices could get problems in the EU.
t1me2die Unfortunately, the same for the EX Docking Station. The stand by consumtion is 2watts per hour (stand by indicator is off). If the stand by indicator is on the consumtion is around 5watts.
Beelink CS-Yvette Hi there, please go to Control Panel, click the Power Options. Select the Choose what the power buttons do. Uncheck the Turn on fast startup (recommended).Select Save Settings.
Beelink CS-Jane troul Hi there,may I know have you try the tutorial?https://buildin.ai/724d0766-6e0a-4dc1-9347-2c4c2cea2d05
Machariel None of these tricks work. Mine is also pulling a few watts when it’s off. Off is off. Please reduce to 0.5 Watts and provide an update. I have a Gti13.
Beelink CS-Jane Machariel Hi there,after shutdown, the machine will automatically enter modern standby mode, so it will still consume power. If you need to completely power off the device, please unplug the power cord.
