LucarioBedwar
Hello LucarioBedwar,
Don’t worry, the PC has one-year warranty.
Could you please send us a picture of SN on the bottom of the PC?
First, Please turn off the PC , unplug the power supply, and press the CMOS button (if no CMOS button, please put the pin in the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms or [https://url.bee-link.cn/5FdW] If the problem persists, please try other solutions:
①Please change another HDMI cable and power supply.
②Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial [https://url.bee-link.cn/AzzB] or https://mega.nz/file/7nwDmCaL#UyzSmVkqJG8HW9dhjHhLkkzdP9gt2Br3xyCG1SCdbrA
Best regards!
Yue
Customer Support
