Please send us a picture of the SN on the bottom of the PC.
Here are the possible solutions :
① About the HDMI ,please update the graphic driver, here is the driver https://url.bee-link.cn/qwOm. Also, Please turn off the PC , unplug the power supply and other USB devices, then put the pin in the CMOS pinhole and press it for about 10 seconds , restart the PC after ten minutes.
Here is the tutorial https://url.bee-link.cn/5FdW
②About the Boot issue, please try to receate a bootable USB flash drive.
③ You can try to reset the PC in another way. Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
Then start the Reset
