①Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc or [https://url.bee-link.cn/AzzB]
②Please take out one RAM and leave the other one in it to test if the RAM is defective or not.** You can also use Memtest software to test the RAM.
③Please update the BIOS https://url.bee-link.cn/1PH1, here is the tutorial https://url.bee-link.cn/brJh
⑤Overheating. If your PC is overheating, please check if the fan spins. You can also turn off the turbo boost. Go to control panel —power option—change to High performance— change plan setting—advanced setting —processor power management— change both 100% to 99% , click save.
⑥Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. https://url.bee-link.cn/KkfG
