Hi there, actually it can suport max 2933 MHZ.
①Please update the BIOS https://url.bee-link.cn/1PH1, here is the tutorial https://url.bee-link.cn/brJh
② Check the kernel panic logs (e.g., dmesg, journalctl -k) for specifics. Errors like “unable to handle kernel paging” may indicate faulty RAM or addressing issues.
③ Please repeatedly press delete key as soon as you turn on the PC, go to BIOS. On Save&Exit page, please click Restore defaults, press enter to confirm, then press F4 to save.
④ Please use the memtest to test the RAM to see they have errors.
