msaempreendimentos Olá, galera estou tendo um probleminha com meu HDMI! Vira e mexe a tela aparecesse sem sinal! alguém sabe como resolvo isso? Meu modelo é o AMD RYZEN 7 5825U!
support1 ① Please unplug the HDMI cable and put it back, make sure it is connected firmly. ②Please go to AMD website and download the auto-detect program.It will update some chipsets and video drivers automatically. It will identify and install appropriate drivers for their AMD hardware. The program works by scanning the user’s system to detect the installed AMD hardware components, such as graphics cards or processors. It then compares the detected hardware information with a database of AMD drivers and software versions.
Danijob Hola ,compre el combo de mini pc junto al docking station ex pro ,pero solo me ha llegado el mini pc ,cuanto tiempo demora en enviarme el docking station ,gracias
support1 Danijob Hi there, sorry for the delay. We are unable to ship the docking station from China due to the high tariff, so we have to send it to our US warehouse first,then send it to you from there. Could you please wait about 2-3 weeks ? Thanks for your patience and kind understanding.
