Beelink CS-Yvette
Please give me instructions; it cannot boot normally, I do not know how to try flashing via USB cable?? The devise is not seen by my TV.
I have been using a male to male USB cable from GT KING II to my computer. My computer regognizes the devise but cannot load via the USB Buring Tool.
I need the GT King II factory USB firmware (.img) that is compatible with Amlogic USB Burning Tool. Please do not send OTA ZIP files — I need the full restore image used for unbricking.
My current firmware file is GTKINGII_Beelink003R0.img, but it is not a true USB image. Please provide the correct factory USB image
Unfortunately, the firmware you provided (GTKING II 003R0) is an OTA update package. It cannot be used with the Amlogic USB Burning Tool, and the device cannot enter USB flash mode with this file.
I specifically need the full factory USB‑flashable firmware image for the GT King II — the complete restore image that includes:
• Bootloader
• DDR init
• Partition table
• Amlogic USB header
Please send the factory USB firmware (.img) used for unbricking the GT King II.
OTA update files will not work for this purpose.
Thank you.
