Could you please send us a picture of  SN code at the bottom of machine and a picture of purchase invoice?
1、You can try to reset the system first:
1)Enter the safe mode, and reset the system.
          Do this many times until Windows  boots into the Recovery Environmen.
2)If Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt . . . etc.
   3)If the above fails, go to Troubleshoot - Advanced Options - Reset this PC
         Then start the Reset
2、You can also try to reinstall the system.
We will send you the corresponding system file after receiving your SN picture.
Could you please send us the  picture? (The method of entering the BIOS is to press delete all the time at the boot interface)
- BIOS save&exit page
Have a nice day!
