Hi, I recently bought a SER5 PRO (model 5825U 32GB/1TB with DP and LAN 2.5). I immediately removed Windows to install Proxmox Linux. Everything works except that the Wifi card is not seen (and consequently not even the BT). The card does not even appear when listing the devices with lspci or lsusb and I don’t know what to do, usually it should be listed even without drivers. Having uninstalled Windows almost immediately I don’t remember if it was present in the system. Any suggestions? Is there a BIOS setup to enable/disable it?
