Evgeny Hello everyone. Can you please tell me if it is possible to get an update for this TV box?Beelink GT-King Pro Amlogic S922X-H Android 9.0 TV Box 4G 64G HiFi Media.Thanks
Evgeny Good day. If the console works correctly, then you can update both the firmware and the android version.. Thanks for the quick response. Evgeniy.
Beelink CS-Yvette Evgeny Hi there, here is the latest firmware https://url.bee-link.cn/f5zp, here the tool: url.bee-link.cn/w367 Tutorial :url.bee-link.cn/cIcR Sorry, but the android version cannot be updated.
Beelink CS-Yvette Homey Hi there, here is the firmware https://url.bee-link.cn/Y9yO , here the tool: url.bee-link.cn/w367 Tutorial :url.bee-link.cn/cIcR
Beelink CS-Yvette hoangcanhhuy Here is the firmware https://url.bee-link.cn/Y9yO, here is tool: https://url.bee-link.cn/w367 Tutorial :https://url.bee-link.cn/cIcR
messi09 Hello, can I get the latest software for my device? beelink gt king pro. My model number is SN:6B9HH1MF20169 64GB BT Can I update the apps using the local update? Thank you in advance.
Beelink CS-Yvette messi09 Here is the firmware https://url.bee-link.cn/Y9yO, here is tool: https://url.bee-link.cn/w367 Tutorial :https://url.bee-link.cn/cIcR
ZvonkoP I have Beelink GT King, my last FW is 926P0_wol_bt , SN: SA9XHQCG80200 64G. Can I get the latest software please? With this one I can not stop working the device, only sleep or reset. When choosen stop, the device resets. Thanks in advance.
Beelink CS-Yvette ZvonkoP Here is the firmware https://url.bee-link.cn/iZTl, tool: url.bee-link.cn/w367 Tutorial :url.bee-link.cn/cIcR
halit61 Beelink GT king s/n: 6B9XH1KG40111 Can I update the apps using the local update? Thank you in advance
Beelink CS-Yvette halit61 We apologize, but it is not possible to upgrade the apps via the local update method.
Beelink CS-Yvette Simonphilip2019 Please provide a photo of the SN code located on the bottom of your machine for our assessment.
Simonphilip2019 I downloaded the firmware. Put it on the SD card insert into the box and updated though the local update with the firmware file from SD card. Thank you
