ChrisMH I am an old old lady trying to set up my AMDRyzen Model Mini SER . It indicates that there is no Audio Device installed. What must I do to get audio?
Beelink CS-June ChrisMH Hello Chris, Could you please send us a picture of SN code at the bottom of machine ? Here are some solutions: 1.Please right click window–click “”setting“—Sound—-more sound setting –click “playback”–right click speaker—properties–controller information —properties—update the driver. You also need to check if the speakers is disabled or not in the playback setting. Here is alternative to troubleshoot the audio problem. https://thegeekpage.com/fix-this-device-cannot-start-code-10-error-in-sound-devices-on-windows-10/#:~:text=%E2%80%9CThis%20device%20cannot%20start.,driver%20installed%20on%20your%20computer. Here is the driver for you to update, Here is the driver :[https://dr.bee-link.cn/?dir=]click the item model , then you can find the related driver. Please turn off the PC , unplug the power supply, and press the CMOS button (or put the pin into the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial [https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w]or [https://url.bee-link.cn/5FdW] Have a nice day!
