This is a fresh install of Windows 11 on a SER9 Pro 370, with every driver installed from Beelink’s site.
While everything works fine, the power consumption looks weird. I took a measure from a Kill-a-watt:
Idle: 15w
Sleep (S0): 6-8w
As an excellent mobile processor, 370 HX SoC’s typical S0 sleep power is 0.61w.
I absolutely have no USB devices attached either (only 1x power cable, 1x Ethernet cable & 1x HDMI cable). There must be something wrong.
Digging deeper,
With powercfg /energy command, I was able to find two faulty USB devices (AMD USB 3.1 XHCI controller on PCI 199 function 0 & 4).
Citing from Microsoft:
USB devices must support selective suspend on Modern Standby devices to ensure that the SoC can enter DRIPS while the screen is off
This is the culprit.
Unfortunately I didn’t find any solution yet. Beelink should solve this bug ASAP.
Screenshots:
USB selective suspend error
The faulty device with consistent D0 power state
