Hi, I have a new ser8 minipc and when using the front usb-c port, the samsung t7shield hangs and the pc slows down. It also creates errors on the disk that need repairing. Right now it is unable to repair.
However, using the back usb-c port works fine, it makes the disk fast, and windows is able to repair the drive.
I tested this with two different usb-c to usb-c cables, and with both, I have errors and slowdowns on the front usb-c port, and no problems and fast performance on the back usb-c ports.
Is there anything I can try on my end before assuming that it is a defective front usb-c port and requesting warranty?
many thanks
