Beelink CS-Bony
What do you mean the main to send you the main page of the BIOS? I haven’t restarted the mini PC since three days, because if I do I might not be able to boot it again. I’m afraid it will brick. If this happens I can’t enter the BIOS and I will have to return it to Amazon. What I read on the Internet a failed BIOS update will most possibly make the PC unusable and the bios can only be updated by de-soldering the chip, flashing it manually and then soldering it again to the motherboard.
The Mini PC is an EQR5 with AMD Ryzen 7 5825u and 32GB. I’m trying to update from BIOS FP656V508 to FP656V509. I also attached a second USB drive and tried to downgrade the BIOS by running again FP656V508, but the same error 43 happened when erasing the NCB Block. I tried also a second time to install FP656V509, but again error 43 when erasing the NCB Block.
The S/N is Y58254LF70039
