D.W
Please send us a picture of SN on the bottom of the PC.
④Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :[https://dr.bee-link.cn/index.php?dir=] , click the item model , then you can find the related driver.
