In the BIOS I see a setting called DT Slot Power Enable with choices of “Enabled (x1) (Lane 0)” (which is the current setting), “Enabled (x2) (Lane 0 + 1)”, “Enabled (x4)” and “Disabled”. Can you explain what the DT Slot is and is my system configured correctly?
Edit: Also, is there a PDF, TXT or file of any sort that explains what all (or at least many) of these BIOS settings mean? I would very much like to download such a file to better understand what all these things mean.
Thank you for your help.
