I have a Mini S device, and it is experiencing a power issue. When I connect the power supply and press the power button, the blue light and the fan turn on, but nothing else happens, no matter how long it stays on.
Sometimes, pressing the reset button for about 10 seconds can temporarily fix the problem, but this happens rarely. I also tried removing the BIOS battery, which sometimes helps as well.
Could you please advise what might be causing this issue and what needs to be repaired?
Thank you in advance.
